Talkgroup Branche mit Fehlermeldung beim Starten
  • Hallo
    Eine tolle Erweiterung !!!!
    Aber leider eine Fehlermeldung beim starten.
    SvxLink v1.7.99.9-reflector_tg Copyright (C) 2003-2019 Tobias Blomberg / SM0SVX
    Using configuration file: /etc/svxlink/svxlinkcb.conf
    --- Using sample rate 48000Hz
    Starting logic: PMRLogic
    Loading RX: Rx1
    Loading TX: Tx1
    Loading module "ModuleParrot" into logic "PMRLogic"
    Found /usr/lib/arm-linux-gnueabihf/svxlink/ModuleParrot.so
    Module Parrot v1.1.1 starting...
    Loading module "ModuleHelp" into logic "PMRLogic"
    Found /usr/lib/arm-linux-gnueabihf/svxlink/ModuleHelp.so
    Module Help v1.0.0 starting...
    Loading module "ModuleMetarInfo" into logic "PMRLogic"
    Found /usr/lib/arm-linux-gnueabihf/svxlink/ModuleMetarInfo.so
    Module MetarInfo v1.2.1 starting...
    Loading module "ModuleWeatherInfo" into logic "PMRLogic"
    Found /usr/lib/arm-linux-gnueabihf/svxlink/ModuleTcl.so
    Module Tcl v1.0.1 starting...
    Loading module "ModuleFrn" into logic "PMRLogic"
    Found /usr/lib/arm-linux-gnueabihf/svxlink/ModuleFrn.so
    Module Frn v1.1.0 starting...
    PMRLogic: Event handler script successfully loaded.
    Starting logic: ReflectorLogic
    svxlink: /opt/src/svxlink/src/svxlink/svxlink/LinkManager.h:179: static LinkManager* LinkManager::instance(): Assertion `_instance != 0' failed.
    Abgebrochen
    73 Jürgen DH9YAP fuinknetz.nrw
