• Hallo...
    Ich bin grade dabei postfix zu installiren.
    nur kommt eine abfrage welches system ich nutzen will
    Package configuration
    ???????? Postfix Configuration ?????????
    ? General type of mail configuration:
    ? No configuration ?
    ? Internet Site ?
    ? Internet with smarthost ?
    ? Satellite system ?
    ? Local only ?
    ? <Ok> <Cancel> ?
    nur welches ist das richtige???
    meine main.cf sieht zur zeit so aus...
    # See /usr/share/postfix/main.cf.dist for a commented, more complete version
    # Debian specific: Specifying a file name will cause the first
    # line of that file to be used as the name. The Debian default
    # is /etc/mailname.
    #myorigin = /etc/mailname
    smtpd_banner = $myhostname ESMTP $mail_name (Debian/GNU)
    biff = no
    # appending .domain is the MUA's job.
    append_dot_mydomain = no
    # Uncomment the next line to generate "delayed mail" warnings
    #delay_warning_time = 4h
    readme_directory = no
    smtpd_tls_cert_file=/etc/ssl/certs/ssl-cert-snakeoil.pem
    smtpd_tls_key_file=/etc/ssl/private/ssl-cert-snakeoil.key
    smtpd_use_tls=yes
    smtpd_tls_session_cache_database = btree:${data_directory}/smtpd_scache
    smtp_tls_session_cache_database = btree:${data_directory}/smtp_scache
    # See /usr/share/doc/postfix/TLS_README.gz in the postfix-doc package for
    # information on enabling SSL in the smtp client.
    myhostname = svxlink
    alias_maps = hash:/etc/aliases
    alias_database = hash:/etc/aliases
    mydestination = Sven, raspberrypi, localhost.localdomain, localhost
    relayhost =
    mynetworks = 127.0.0.0/8 [::ffff:127.0.0.0]/104 [::1]/128
    mailbox_command = /usr/bin/procmail
    queue_minfree = 0
    mailbox_size_limit = 512000
    massage_size_limit = 128000
    recipient_delimiter =
    inet_interfaces = all
    inet_protocols = ipv4
    default_transport = error
    relay_transport = error
    mydomain = xxxxxxxxxxxxx.no-ip.biz
    weis einer vieleicht weiter ?????
    73 DO7SK
  • Hi Sven,
    schau mal unter /var/spool/mail/
    Da gibt es eine Datei, die dem Usernamen entspricht.
    Wenn Du die procmail schon aktiviert hast, sollte es im Homeverzeichnis des Users (in Deinem Falle "svxlink", also im Verzeichnis /home/svxlink) eine Datei namens procmail.log geben, dort wird ausgegeben was Dein System macht.
    -Die Datei procmail.log gibt es nicht.
    #schau mal unter /var/spool/mail/
    #Da gibt es eine Datei, die dem Usernamen entspricht.
    -gibt es leider auch nicht
    pi@raspberrypi ~ $ ps ax|grep postfix
    2247 ? Ss 0:01 /usr/lib/postfix/master
    8430 pts/0 S+ 0:00 grep --color=auto postfix
    pi@raspberrypi ~ $
    ich weis leider nicht mehr weiter....
    73 DO7SK-Sven
