ich habe folgendes Problem. Mein SVXlink läuft auf einem RaspberryPi mit Debian.
Seit kurzem möchte mein SVXlink nicht immer beim ersten Start starten. Teilweise braucht er 2-3 Anläufe damit er die USB Soundkarte nimmt.
svxlink@raspberrypi ~ $ svxlinkSvxLink v0.13.99.15 (Jan 16 2013) Copyright (C) 2011 Tobias Blomberg / SM0SVXSvxLink comes with ABSOLUTELY NO WARRANTY. This is free software, and you arewelcome to redistribute it in accordance with the terms and conditions in theGNU GPL (General Public License) version 2 or later.Using configuration file: /etc/svxlink/svxlink.conf--- Using sample rate 48000HzStarting logic: SimplexLogicSel5 macro range from 57000 to 59000Adding receiver to Voter: Rx1Starting ZVEI1 decoder*** ERROR: Open capture audio device failed: Device or resource busy*** Error: Could not open audio device for receiver "Rx1"*** ERROR: Could not initialize RX "Voter"*** ERROR: Could not initialize Logic object "SimplexLogic". Skipping...*** ERROR: No logics available. Bailing out...svxlink@raspberrypi ~ $ svxlinkSvxLink v0.13.99.15 (Jan 16 2013) Copyright (C) 2011 Tobias Blomberg / SM0SVXSvxLink comes with ABSOLUTELY NO WARRANTY. This is free software, and you arewelcome to redistribute it in accordance with the terms and conditions in theGNU GPL (General Public License) version 2 or later.Using configuration file: /etc/svxlink/svxlink.conf--- Using sample rate 48000HzStarting logic: SimplexLogicSel5 macro range from 57000 to 59000Adding receiver to Voter: Rx1Starting ZVEI1 decoderAdding receiver to Voter: NetRxAdding transmitter: NetTxAdding transmitter: Tx1Loading module "ModuleParrot" into logic "SimplexLogic" Module Parrot v0.7.0.99.0 starting...Loading module "ModuleHelp" into logic "SimplexLogic" Module Help v0.7.0.99.0 starting...Loading module "ModuleEchoLink" into logic "SimplexLogic" Module EchoLink v0.10.99.1 starting...Loading module "ModuleMetarInfo" into logic "SimplexLogic" Module MetarInfo v0.0.2.99.1 starting...Loading module "ModuleSelCallEnc" into logic "SimplexLogic" Module Tcl v0.3.0.99.0 starting...Event handler script successfully loaded.Connected to APRS server 85.90.180.26 on port 14580EchoLink directory status changed to ON--- EchoLink directory server message: ---EchoLink Server v2.5.9997ECHOEC2-1: Herndon, VA USA
Gibt es ein mittel um dieses Problem zu lösen? Bin noch Linux Anfänger bitte um nachsicht.
Mein 2. Problem ist der RemoteTrx. Habe die Conf. laut http://svxlink.de/?page_id=1228 vorgenommen. Nur leider bekomme ich auch da wieder eine Fehlermeldung im bezug auf meine Soundkarte.
svxlink@raspberrypi ~ $ remotetrx
RemoteTrx v0.3.2.99.12 (Jan 16 2013) Copyright (C) 2011 Tobias Blomberg / SM0SVX
RemoteTrx comes with ABSOLUTELY NO WARRANTY. This is free software, and you are
Using configuration file: /etc/svxlink/remotetrx.conf
Setting up trx "NetUplinkTrx"
*** ERROR: Could not initialize rx object "Rx1" for trx "NetUplinkTrx".
*** ERROR: Failed to setup trx NetUplinkTrx
*** ERROR: No trxs successfully initialized. Bailing out...
Display More
Kann es mit dem ersten Fehler zusammenhängen??
73 de SA7BNT
Tim
