Send mail with TclVoiceMail...
  • Hello,
    I use TclVoiceMail, and when i have the voice message,TclVoiceMail send a mail in the log, no problem, but i don't receive the mail in my personnal box :?
    have you idea ?
    I use Raspberry Pi and i install Mutt and the test is OK ( no problem for send mail via Mutt at my personnal mail and no problem for respond )
    The log for example....
    TclVoiceMail: Recording subject to file: /var/spool/svxlink/voice_mail/F4FPQ/20130610_081756_***_subj.wav
    TclVoiceMail: Recording message to file: /var/spool/svxlink/voice_mail/F4FPQ/20130610_081756_***_mesg.wav
    Rx1: The squelch is CLOSED (5.95874)
    TclVoiceMail: Sending notification e-mail to "f4fpq@free.fr"
    Tx1: Turning the transmitter ON
    Tx1: Turning the transmitter OFF
    # TclVoiceMail configuration
    # The user list.
    # Format: set users(userid) "call=callsign pass=password email=mail_address";
    # userid - A three digit code that identifies the user
    # callsign - The callsign of the user
    # password - The users password. One to seven digits.
    # email - The e-mail address to send a text message to when a new voice
    # mail have arrived. This is optional.
    set users(***) "call=F4FPQ pass=*** email=f4fpq@free.fr;
    # The directory where the voice mails are stored
    set recdir "/var/spool/svxlink/voice_mail";
    # Maximum recording times in milliseconds
    set max_subj_time 10000
    set max_mesg_time 120000
    # These settings are used when sending e-mail to users when a new voice mail
    # has been recorded for that user.
    # mail_from_addr - The used from-address
    # mail_from_name - The displayed name of the sender
    # mai_subj - The subject of the message
    # mail_msg - The message body
    set mail_from_addr "f4fpq.link@free.fr";
    set mail_from_name "SvxLink Voice Mail";
    set mail_subj "SvxLink: New voice mail received";
    set mail_msg {Hi!
    You have received a new voice mail at SvxLink node $Logic::CFG_CALLSIGN
    from [id2var $userid call].
    To listen to your voice mail, follow these steps:
    1. Activate the voice mail module using DTMF $CFG_ID#
    2. Login by using DTMF $rec_rcpt[id2var $rec_rcpt pass]#
    3. Listen to your message using 1#
    73 de MYCALL / MyName};
    And Mutt config ( .muttrc )
    # configuration de base
    set realname = "F4FPQ-LINK"
    set header_cache =~/.mutt/cache/headers
    set certificate_file =~/.mutt/certificates
    set message_cachedir =~/.mutt/cache/bodies
    # configuration imap
    set spoolfile=imaps://imap.free.fr/INBOX
    set imap_user = "f4fpq.link@free.fr"
    set imap_pass = "****"
    set imap_passive="no"
    set imap_check_subscribed="yes"
    set imap_list_subscribed="yes"
    # configuration SMTP
    set smtp_url = "smtp://smtp.free.fr/"
    set smtp_pass = "****"
    set from = "f4fpq.link@free.fr"
    set use_envelope_from=yes # Pour que postfix ou sendmail ne change pas votre from
    # locales FR pour les nom des jours et mois
    set locale="fr_FR"
    # Format de date
    set date_format="%A %d %b %Y � %H:%M:%S (%Z)"
    # phrase d'intro pour reponse quotee
    set attribution="Le %d, %n a ecrit :"
    set forward_format="[Fwd: %s]"
    set forward_quote
    mailboxes !
    #Editeur
    set edit_hdrs
    auto_view text/html
    #set editor="nano" # indiquer ici votre editeur de texte prefere
    color attachment magenta default # attachments
    color body brightred default "(ftp|http)://[^ ]+" # point out URLs
    color body brightcyan default [-a-z_0-9.]+@[-a-z_0-9.]+ # e-mail addresses
    color bold brightblue default # boldface text
    color error brightwhite red # error messages
    color hdrdefault magenta default # default color of message header
    color header brightmagenta default ^(From): # From and Subject header
    color header brightwhite default ^(Subject): # From and Subject header
    color header brightwhite default ^(Date): # Date header
    color header white default ^(In-Reply-To):
    color indicator brightred default # indicator bar
    color markers brightblue default # wrapped line markers (+)
    color message brightblack green # status messages
    color normal default default # default
    color quoted yellow default # quoted text, 1st quote level
    color quoted1 green default # quoted text, 2nd quote level
    color quoted2 brightblue default # quoted text, 3rd quote level
    color quoted3 blue default # quoted text, 4th quoet level
    color search black yellow # matched search patterns in pager
    color signature red default # the signature (after sigdashes)
    color status default blue # status lines
    color tilde brightblue default # ``~'' used to pad blank lines
    color tree green default # thread tree in the index menu
    color underline brightgreen default # underlined text
    # Pour la gestion des accents
    set locale="iso-8859-15"
    set pager_index_lines=7
    set pager_stop
    Very thank's for your Idea and escuse me the the bad english 73 :P
    Thierry F4FPQ
  • Hi Thierry,
    do you have a bit more debug infos? I'm not familar with mutt, does it have a logfile and is it enabled?
    Under which userid is svxlink running, e.g. svxlink:users ? Can you try to send an eMail as the same user like svxlink does using mutt with the same options:
    mutt -s "Subject" destination@email.fr -e "set from="your_from@address.fr"" -e "set realname="from_name"" "your message"
    There are some points that can make trouble, e.g. some providers doesn't accept eMails with an IP-address that doesn't fit into her own network.
    On some systems only root can change their own email-sender-address. Did you received any messages on your system (in /var/spool/mail/$username)?
  • Hello Ady,
    And very thank's for your respond...
    In my Raspberry Pi i have : the root user and the pi user, the SVXLINK program is on "pi" user
    I test yout Mutt command :
    mutt -s "Subject" f4fpq@free.fr -e "set from="f4fpq.link@free.fr"" -e "set realname="F4FPQ.LINK"" "your message"
    i have in "To" f4fpq@free.fr, yourmessage@raspberrypi ...?
    And a error message when i send the mail :
    "SMTP session failed: 504 5.5.2 <yourmessage@raspberrypi>: Recipient address reje"
    But when i test this command
    i have just in "To" f4fpq@free.fr
    And no problem with the smtp server of free, i receive the mail ....
    Thank's Thierry
  • Hi Thierry,
    hm, I see I have to configure my TclVoiceMail first to see what happen. At the moment I do not use this feature. Please let me some time to check this out, ok?
  • Hello Adi,
    I have a news,
    I have this log when the module TclVoiceMail send a mail ....
    var/log/exim4
    2013-06-11 18:58:52 1UmRuG-0000fd-5G <= root@raspberrypi U=root P=local S=741 id=20130611165851.GA2572@raspberrypi
    2013-06-11 18:58:52 1UmRuG-0000fd-5G ** f4fpq@free.fr R=nonlocal: Mailing to remote domains not supported
    2013-06-11 18:58:52 1UmRuG-0000fh-Hd <= <> R=1UmRuG-0000fd-5G U=Debian-exim P=local S=1540
    2013-06-11 18:58:52 1UmRuG-0000fd-5G Completed
    2013-06-11 18:58:52 1UmRuG-0000fh-Hd => /var/mail/mail <root@raspberrypi> R=mail4root T=address_file
    2013-06-11 18:58:52 1UmRuG-0000fh-Hd Completed
    After, i test with uninstall Mutt, and I have this log, in the the of screen of svxlink...
    *** ERROR: Unable to handle event: TclVoiceMail::squelchOpen 0 in logic SimplexLogic (couldn't execute "mutt": no such file or directory)
    73 Thierry
  • Hello Adi,
    The super user is a idea, but in the ModuleTclVoiceMail.tcl are there any possibility for change the command with this statut ? :roll:
    ~/svxlink-trunk/svxlink/modules/tcl_voice_mail $ sudo nano ModuleTclVoiceMail.tcl
    #exec mail -s "$mail_subj" $email -- -f $mail_from_addr \
    # -F "$mail_from_name" << "$msg" &;
    exec mutt -s "$mail_subj" $email \
    -e "set from=\"$mail_from_addr\"" \
    -e "set realname=\"$mail_from_name\"" \
    << "$msg" &;
    set rec_rcpt "";
    setState "logged_in";
    Good week at you with ths sun 73 ! :P
    Thierry
