Fehler nach Update
    Ich habe bei Svxlink ein update gemacht aber leider ist was schiefgelaufen er will die Module nicht mehr laden.
    Ich habe sogar einmal alles neu Kompilieren lassen aber kein erfolg.
    73 DO7SK
    Hier ist einaml das Log
    SvxLink v1.5.0 Copyright (C) 2003-2015 Tobias Blomberg / SM0SVX
    Using configuration file: /etc/svxlink/svxlink.conf
    --- Using sample rate 48000Hz
    *** WARNING: missing param DF0HHH2/TIMEOUT=??, set to default (30 sec)
    *** WARNING: missing param Handy-70cm/TIMEOUT=??, set to default (30 sec)
    Starting logic: RepeaterLogic70cm
    Loading RX: Voter70cm
    Adding receiver: Rx-70cm
    Loading TX: MultiTx70cm
    Adding transmitter: Tx-70cm
    *** WARNING: The DTMF_TONE_AMP configuration variable set in transmitter Tx-70cm is deprecated. Use DTMF_DIGIT_PWR instead. To get the same output level uing the new configuration variable, add 3dB to the old value.
    Loading module "ModuleHelp" into logic "RepeaterLogic70cm"
    Found /usr/lib/svxlink/ModuleHelp.so
    Module Help v1.0.0 starting...
    *** ERROR: This module is compiled for version 1.4.99.21 of SvxLink but the running version of the SvxLink core is 1.5.0.
    *** ERROR: Initialization failed for module ModuleHelp in logic RepeaterLogic70cm
    Loading module "ModuleParrot" into logic "RepeaterLogic70cm"
    *** ERROR: Failed to load module ModuleParrot into logic RepeaterLogic70cm: /usr/lib/svxlink/ModuleParrot.so: undefined symbol: _ZN5Async5TimerC1EiNS0_4TypeE
    Loading module "ModuleEchoLink" into logic "RepeaterLogic70cm"
    Found /usr/lib/svxlink/ModuleEchoLink.so
    Module EchoLink v1.3.1.99.1 starting...
    *** ERROR: Initialization failed for module ModuleEchoLink in logic RepeaterLogic70cm
    Loading module "ModuleTclVoiceMail" into logic "RepeaterLogic70cm"
    Found /usr/lib/svxlink/ModuleTcl.so
    Module Tcl v1.0.1 starting...
    *** ERROR: Initialization failed for module ModuleTclVoiceMail in logic RepeaterLogic70cm
    Loading module "ModuleDtmfRepeater" into logic "RepeaterLogic70cm"
    *** ERROR: Failed to load module ModuleDtmfRepeater into logic RepeaterLogic70cm: /usr/lib/svxlink/ModuleDtmfRepeater.so: undefined symbol: _ZN5Async5TimerC1EiNS0_4TypeE
    Loading module "ModuleMetarInfo" into logic "RepeaterLogic70cm"
    Found /usr/lib/svxlink/ModuleMetarInfo.so
    Module MetarInfo v1.0.0.99.2 starting...
    *** ERROR: Initialization failed for module ModuleMetarInfo in logic RepeaterLogic70cm
    Loading module "ModuleSelCallEnc" into logic "RepeaterLogic70cm"
    *** ERROR: Initialization failed for module ModuleSelCallEnc in logic RepeaterLogic70cm
    RepeaterLogic70cm: Event handler script successfully loaded.
    *** ERROR: Unable to handle event: RepeaterLogic70cm::startup in logic RepeaterLogic70cm (invalid command name "RepeaterLogic70cm::startup")
    Starting logic: RepeaterLogic2m
    Loading RX: Voter2m
    Adding receiver: DM0MAX-Rx-2m
    Adding receiver: Remote-Rx-2m_DO7CT
    Loading TX: MultiTx2m
    Adding transmitter: DM0MAX-Tx-2m
    ------ Opus encoder parameters ------
    Frame size = 320
    Complexity = 10
    Bitrate = 20000
    VBR = YES
    Constrained VBR = YES
    Maximum audio bw = MEDIUMBAND
    Audio bw = FULLBAND
    Signal type = VOICE
    Application type = AUDIO
    Inband FEC = NO
    Expected Packet Loss = 0%
    DTX = NO
    Loading module "ModuleHelp" into logic "RepeaterLogic2m"
    *** ERROR: Initialization failed for module ModuleHelp in logic RepeaterLogic2m
    Loading module "ModuleParrot" into logic "RepeaterLogic2m"
    *** ERROR: Failed to load module ModuleParrot into logic RepeaterLogic2m: /usr/lib/svxlink/ModuleParrot.so: undefined symbol: _ZN5Async5TimerC1EiNS0_4TypeE
    Loading module "ModuleEchoLink" into logic "RepeaterLogic2m"
    *** ERROR: Initialization failed for module ModuleEchoLink in logic RepeaterLogic2m
    Loading module "ModuleTclVoiceMail" into logic "RepeaterLogic2m"
    *** ERROR: Initialization failed for module ModuleTclVoiceMail in logic RepeaterLogic2m
    Loading module "ModuleDtmfRepeater" into logic "RepeaterLogic2m"
    *** ERROR: Failed to load module ModuleDtmfRepeater into logic RepeaterLogic2m: /usr/lib/svxlink/ModuleDtmfRepeater.so: undefined symbol: _ZN5Async5TimerC1EiNS0_4TypeE
    Loading module "ModuleMetarInfo" into logic "RepeaterLogic2m"
    *** ERROR: Initialization failed for module ModuleMetarInfo in logic RepeaterLogic2m
    Loading module "ModuleSelCallEnc" into logic "RepeaterLogic2m"
    *** ERROR: Initialization failed for module ModuleSelCallEnc in logic RepeaterLogic2m
    RepeaterLogic2m: Event handler script successfully loaded.
    Starting logic: RepeaterLogic10m
    Loading RX: Voter10m
    Adding receiver: Remote-Rx-10m_DB0MAX
    Adding receiver: Remote-Rx-10m_DO7CT
    Adding receiver: Remote-Rx-10m_DB0NLH
    Loading TX: MultiTx10m
    Adding transmitter: DM0MAX-Tx-10m
    Frame size = 320
    Complexity = 10
    Bitrate = 20000
    VBR = YES
    Audio bw = FULLBAND
    Signal type = VOICE
    Inband FEC = NO
    DTX = NO
    Adding transmitter: StremingTx
    Loading module "ModuleHelp" into logic "RepeaterLogic10m"
    *** ERROR: Initialization failed for module ModuleHelp in logic RepeaterLogic10m
    Loading module "ModuleParrot" into logic "RepeaterLogic10m"
    *** ERROR: Failed to load module ModuleParrot into logic RepeaterLogic10m: /usr/lib/svxlink/ModuleParrot.so: undefined symbol: _ZN5Async5TimerC1EiNS0_4TypeE
    Loading module "ModuleEchoLink" into logic "RepeaterLogic10m"
    *** ERROR: Initialization failed for module ModuleEchoLink in logic RepeaterLogic10m
    Loading module "ModuleTclVoiceMail" into logic "RepeaterLogic10m"
    *** ERROR: Initialization failed for module ModuleTclVoiceMail in logic RepeaterLogic10m
    Loading module "ModuleDtmfRepeater" into logic "RepeaterLogic10m"
    *** ERROR: Failed to load module ModuleDtmfRepeater into logic RepeaterLogic10m: /usr/lib/svxlink/ModuleDtmfRepeater.so: undefined symbol: _ZN5Async5TimerC1EiNS0_4TypeE
    Loading module "ModuleMetarInfo" into logic "RepeaterLogic10m"
    *** ERROR: Initialization failed for module ModuleMetarInfo in logic RepeaterLogic10m
    Loading module "ModuleSelCallEnc" into logic "RepeaterLogic10m"
    *** ERROR: Initialization failed for module ModuleSelCallEnc in logic RepeaterLogic10m
    RepeaterLogic10m: Event handler script successfully loaded.
    Starting logic: MicSpkrLogic
    Loading RX: Voter-DO7CT
    Adding receiver: Remote-Rx_DO7CT
    Loading TX: MultiTx-DO7CT
    Adding transmitter: Remote-Tx_DO7CT
    Frame size = 320
    Complexity = 10
    Bitrate = 20000
    VBR = YES
    Audio bw = FULLBAND
    Signal type = VOICE
    Inband FEC = NO
    DTX = NO
    MicSpkrLogic: Event handler script successfully loaded.
    Starting logic: NetLogic
    Loading RX: NetRx
    Loading TX: NetTx
    Frame size = 320
    Complexity = 10
    Bitrate = 20000
    VBR = YES
    Audio bw = FULLBAND
    Signal type = VOICE
    Inband FEC = NO
    DTX = NO
    NetLogic: Event handler script successfully loaded.
    Starting logic: MicSpkrLogic-Handy
    Loading RX: DO7SK-Rx_Handy
    Loading TX: DO7SK-Tx_Handy
    Frame size = 320
    Complexity = 10
    Bitrate = 20000
    VBR = YES
    Audio bw = FULLBAND
    Signal type = VOICE
    Inband FEC = NO
    DTX = NO
    Loading module "ModuleHelp" into logic "MicSpkrLogic-Handy"
    *** ERROR: Initialization failed for module ModuleHelp in logic MicSpkrLogic-Handy
    Loading module "ModuleParrot" into logic "MicSpkrLogic-Handy"
    *** ERROR: Failed to load module ModuleParrot into logic MicSpkrLogic-Handy: /usr/lib/svxlink/ModuleParrot.so: undefined symbol: _ZN5Async5TimerC1EiNS0_4TypeE
    Loading module "ModuleEchoLink" into logic "MicSpkrLogic-Handy"
    *** ERROR: Initialization failed for module ModuleEchoLink in logic MicSpkrLogic-Handy
    Loading module "ModuleTclVoiceMail" into logic "MicSpkrLogic-Handy"
    *** ERROR: Initialization failed for module ModuleTclVoiceMail in logic MicSpkrLogic-Handy
    Loading module "ModuleDtmfRepeater" into logic "MicSpkrLogic-Handy"
    *** ERROR: Failed to load module ModuleDtmfRepeater into logic MicSpkrLogic-Handy: /usr/lib/svxlink/ModuleDtmfRepeater.so: undefined symbol: _ZN5Async5TimerC1EiNS0_4TypeE
    Loading module "ModuleMetarInfo" into logic "MicSpkrLogic-Handy"
    *** ERROR: Initialization failed for module ModuleMetarInfo in logic MicSpkrLogic-Handy
    Loading module "ModuleSelCallEnc" into logic "MicSpkrLogic-Handy"
    *** ERROR: Initialization failed for module ModuleSelCallEnc in logic MicSpkrLogic-Handy
    MicSpkrLogic-Handy: Event handler script successfully loaded.
    Ich habe jetzt die Dateien manuel in das Verzeichnis /usr/lib/svxlink/
    kopiert jetzt geht es.
    Ist das ein fehler im Programm oder habe ich was falsch gemacht.
    73 DO7SK
  • Hi Sven,
    das ist ein Problem mit dem Updateskript und bekannt. Das hatte ich auch schon hier bei mir. Du hast es richtig gemacht, im Prinzip reicht das Löschen der SvxLink-libs /usr/lib/... aus.
    Das Ganze sollte beim nächsten Update nicht mehr auftreten.
