So jetzt laufen keine Module mehr, weil sie alle für die alte Version kompiliert wurden.
Fri May 19 14:55:46 2017: SIGTERM received. Shutting down application...
Fri May 19 14:56:54 2017: SvxLink v1.5.99.5 Copyright (C) 2003-2017 Tobias Blomberg / SM0SVX
Fri May 19 14:56:54 2017: SvxLink comes with ABSOLUTELY NO WARRANTY. This is free software, and you are
Fri May 19 14:56:54 2017: welcome to redistribute it in accordance with the terms and conditions in the
Fri May 19 14:56:54 2017: GNU GPL (General Public License) version 2 or later.
Fri May 19 14:56:54 2017: Using configuration file: /etc/svxlink/svxlink.conf
Fri May 19 14:56:54 2017: --- Using sample rate 48000Hz
Fri May 19 14:56:54 2017: Starting logic: RepeaterLogic
Fri May 19 14:56:54 2017: Loading RX: Rx1
Fri May 19 14:56:54 2017: Home directory not accessible: Permission denied
Fri May 19 14:56:54 2017: Loading TX: Tx1
Fri May 19 14:56:54 2017: *** WARNING: The DTMF_TONE_AMP configuration variable set in transmitter Tx1 is deprecated. Use DTMF_DIGIT_PWR instead. To get the same output level uing the new configuration variable, add 3dB to the old value.
Fri May 19 14:56:54 2017: Loading module "ModuleHelp" into logic "RepeaterLogic"
Fri May 19 14:56:54 2017: Found /usr/lib/svxlink/ModuleHelp.so
Fri May 19 14:56:54 2017: Module Help v1.0.0 starting...
Fri May 19 14:56:54 2017: *** ERROR: This module is compiled for version 1.4.0 of SvxLink but the running version of the SvxLink core is 1.5.99.5.
Fri May 19 14:56:54 2017: *** ERROR: Initialization failed for module ModuleHelp in logic RepeaterLogic
Fri May 19 14:56:54 2017: Loading module "ModuleEchoLink" into logic "RepeaterLogic"
Fri May 19 14:56:54 2017: Found /usr/lib/svxlink/ModuleEchoLink.so
Fri May 19 14:56:54 2017: Module EchoLink v1.3.0 starting...
Fri May 19 14:56:54 2017: *** ERROR: Initialization failed for module ModuleEchoLink in logic RepeaterLogic
Fri May 19 14:56:54 2017: Loading module "ModuleParrot" into logic "RepeaterLogic"
Fri May 19 14:56:54 2017: *** ERROR: Failed to load module ModuleParrot into logic RepeaterLogic: /usr/lib/svxlink/ModuleParrot.so: undefined symbol: _ZN5Async5TimerC1EiNS0_4TypeE
Fri May 19 14:56:54 2017: Loading module "ModuleMetarInfo" into logic "RepeaterLogic"
Fri May 19 14:56:54 2017: Found /usr/lib/svxlink/ModuleMetarInfo.so
Fri May 19 14:56:54 2017: Module MetarInfo v1.0.0 starting...
Fri May 19 14:56:54 2017: *** ERROR: Initialization failed for module ModuleMetarInfo in logic RepeaterLogic
Fri May 19 14:56:54 2017: RepeaterLogic: Event handler script successfully loaded.
Fri May 19 14:58:38 2017:
Fri May 19 14:58:38 2017: SIGTERM received. Shutting down application...
Fri May 19 14:59:41 2017: SvxLink v1.5.99.5 Copyright (C) 2003-2017 Tobias Blomberg / SM0SVX
Fri May 19 14:59:41 2017: SvxLink comes with ABSOLUTELY NO WARRANTY. This is free software, and you are
Fri May 19 14:59:41 2017: welcome to redistribute it in accordance with the terms and conditions in the
Fri May 19 14:59:41 2017: GNU GPL (General Public License) version 2 or later.
Fri May 19 14:59:41 2017: Using configuration file: /etc/svxlink/svxlink.conf
Fri May 19 14:59:41 2017: --- Using sample rate 48000Hz
Fri May 19 14:59:41 2017: Starting logic: RepeaterLogic
Fri May 19 14:59:41 2017: Loading RX: Rx1
Fri May 19 14:59:41 2017: Home directory not accessible: Permission denied
Fri May 19 14:59:41 2017: Loading TX: Tx1
Fri May 19 14:59:41 2017: *** WARNING: The DTMF_TONE_AMP configuration variable set in transmitter Tx1 is deprecated. Use DTMF_DIGIT_PWR instead. To get the same output level uing the new configuration variable, add 3dB to the old value.
Fri May 19 14:59:41 2017: Loading module "ModuleHelp" into logic "RepeaterLogic"
Fri May 19 14:59:41 2017: Found /usr/lib/svxlink/ModuleHelp.so
Fri May 19 14:59:41 2017: Module Help v1.0.0 starting...
Fri May 19 14:59:41 2017: *** ERROR: This module is compiled for version 1.4.0 of SvxLink but the running version of the SvxLink core is 1.5.99.5.
Fri May 19 14:59:41 2017: *** ERROR: Initialization failed for module ModuleHelp in logic RepeaterLogic
Fri May 19 14:59:41 2017: Loading module "ModuleEchoLink" into logic "RepeaterLogic"
Fri May 19 14:59:41 2017: Found /usr/lib/svxlink/ModuleEchoLink.so
Fri May 19 14:59:41 2017: Module EchoLink v1.3.0 starting...
Fri May 19 14:59:41 2017: *** ERROR: Initialization failed for module ModuleEchoLink in logic RepeaterLogic
Fri May 19 14:59:41 2017: Loading module "ModuleParrot" into logic "RepeaterLogic"
Fri May 19 14:59:41 2017: *** ERROR: Failed to load module ModuleParrot into logic RepeaterLogic: /usr/lib/svxlink/ModuleParrot.so: undefined symbol: _ZN5Async5TimerC1EiNS0_4TypeE
Fri May 19 14:59:41 2017: Loading module "ModuleMetarInfo" into logic "RepeaterLogic"
Fri May 19 14:59:41 2017: Found /usr/lib/svxlink/ModuleMetarInfo.so
Fri May 19 14:59:41 2017: Module MetarInfo v1.0.0 starting...
Fri May 19 14:59:41 2017: *** ERROR: Initialization failed for module ModuleMetarInfo in logic RepeaterLogic
Fri May 19 14:59:41 2017: RepeaterLogic: Event handler script successfully loaded.
Fri May 19 15:00:00 2017: RepeaterLogic: Sending long identification...
Fri May 19 15:00:00 2017: Tx1: Turning the transmitter ON
Fri May 19 15:00:07 2017: Tx1: Turning the transmitter OFF
Fri May 19 15:10:00 2017: RepeaterLogic: Sending short identification...
Fri May 19 15:10:00 2017: Tx1: Turning the transmitter ON
Fri May 19 15:10:03 2017: Tx1: Turning the transmitter OFF
