ich habe leider ein Problem mit einem SDR-Stick Svxlink will nicht so wirklich mit im arbeiten.
hier ist einmal eine Fehlermeldung und die config,
vielicht hat ja jemand eine idee???
sudo siglevdetcal /etc/svxlink/svxlink.conf Rx1
SigLevDetCal v1.0.7.99.0 Copyright (C) 2003-2019 Tobias Blomberg / SM0SVX
SigLevDetCal comes with ABSOLUTELY NO WARRANTY. This is free software, and you
are welcome to redistribute it in accordance with the terms and conditions in
the GNU GPL (General Public License) version 2 or later.
--- Using sample rate 48000Hz
--- Adjust the audio input level to a suitable level.
--- Transmit a strong signal into the SvxLink receiver.
--- This will represent the strongest possible input signal.
--- Don't release the PTT until told so.
--- Press ENTER when ready.
Found Rafael Micro R820T tuner
[R82XX] PLL not locked!
WbRx1: Changed state to READY
Using device : [0] Realtek RTL2838UHIDIR SN:00000001
Tuner type : R820T
Valid tuner gains : 0 0.9 1.4 2.7 3.7 7.7 8.7 12.5 14.4 15.7 16.6 19.7 20.7 22.9 25.4 28 29.7 32.8 33.8 36.4 37.2 38.6 40.2 42.1 43.4 43.9 44.5 48 49.6
-------------- Config ------------------
[Rx1]
TYPE=Ddr
#TYPE=Dummy
#SQL_DET=SIGLEV
SQL_DET=OPEN
SIGLEV_DET=DDR
SIGLEV_SLOPE=0.0
SIGLEV_OFFSET=0.0
SIGLEV_OPEN_THRESH=20
SIGLEV_CLOSE_THRESH=10
DEEMPHASIS=1
FQ=1000000000
#MODULATION=NBFM
SQL_TAIL_ELIM=300
PREAMP=0
DTMF_DEC_TYPE=INTERNAL
DTMF_MUTING=1
DTMF_HANGTIME=100
1750_MUTING=0
WBRX=WbRx1
[WbRx1]
TYPE=RtlUsb
#HOST=127.0.0.1
#PORT=1234
#CENTER_FQ=0
#DEV_MATCH=0
FQ_CORR=0
GAIN=10
SAMPLE_RATE=960000
DO7SK - Sven
