Fehlermeldung bei Installation (Branche Talkgroup)
  • Hallo
    ich hab schon 3 Installationen des Branche Talkgroup) erfolgreich durchgeführt,aber ein Raspberry Pi verweigert sich.
    Was bedeutet die Fehlermeldung bzw wie bekomme ich das am laufen ?
    73 Jürgen
    [ 52%] Building CXX object svxlink/digital/CMakeFiles/digital.dir/Synchronizer.c pp.o
    [ 52%] Building CXX object svxlink/digital/CMakeFiles/digital.dir/HdlcDeframer.c pp.o
    [ 53%] Building CXX object svxlink/digital/CMakeFiles/digital.dir/AfskModulator. cpp.o
    [ 53%] Building CXX object svxlink/digital/CMakeFiles/digital.dir/HdlcFramer.cpp .o
    [ 53%] Building CXX object svxlink/digital/CMakeFiles/digital.dir/Fcs.cpp.o
    [ 54%] Linking CXX static library libdigital.a
    [ 54%] Built target digital
    Scanning dependencies of target cal_sound_card
    [ 54%] Building CXX object svxlink/digital/CMakeFiles/cal_sound_card.dir/cal_sou nd_card.cpp.o
    [ 54%] Linking CXX executable cal_sound_card
    [ 54%] Built target cal_sound_card
    Scanning dependencies of target trx
    [ 54%] Building CXX object svxlink/trx/CMakeFiles/trx.dir/ToneDetector.cpp.o
    [ 56%] Building CXX object svxlink/trx/CMakeFiles/trx.dir/Dh1dmSwDtmfDecoder.cpp .o
    [ 56%] Building CXX object svxlink/trx/CMakeFiles/trx.dir/Rx.cpp.o
    [ 56%] Building CXX object svxlink/trx/CMakeFiles/trx.dir/LocalRx.cpp.o
    [ 57%] Building CXX object svxlink/trx/CMakeFiles/trx.dir/SquelchVox.cpp.o
    [ 57%] Building CXX object svxlink/trx/CMakeFiles/trx.dir/SigLevDetNoise.cpp.o
    [ 57%] Building CXX object svxlink/trx/CMakeFiles/trx.dir/NetRx.cpp.o
    [ 58%] Building CXX object svxlink/trx/CMakeFiles/trx.dir/Voter.cpp.o
    /opt/src/svxlink/src/svxlink/trx/Voter.cpp: In member function ‘void Voter::prin tSquelchState()’:
    /opt/src/svxlink/src/svxlink/trx/Voter.cpp:713:3: error: ‘StreamWriterBuilder’ i s not a member of ‘Json’
    Json::StreamWriterBuilder builder;
    /opt/src/svxlink/src/svxlink/trx/Voter.cpp:714:3: error: ‘builder’ was not decla red in this scope
    builder["commentStyle"] = "None";
    /opt/src/svxlink/src/svxlink/trx/Voter.cpp:716:3: error: ‘StreamWriter’ is not a member of ‘Json’
    Json::StreamWriter* writer = builder.newStreamWriter();
    /opt/src/svxlink/src/svxlink/trx/Voter.cpp:716:23: error: ‘writer’ was not decla red in this scope
    /opt/src/svxlink/src/svxlink/trx/Voter.cpp:719:10: error: type ‘<type error>’ ar gument given to ‘delete’, expected pointer
    delete writer;
    svxlink/trx/CMakeFiles/trx.dir/build.make:230: recipe for target 'svxlink/trx/CM akeFiles/trx.dir/Voter.cpp.o' failed
    make[2]: *** [svxlink/trx/CMakeFiles/trx.dir/Voter.cpp.o] Error 1
    CMakeFiles/Makefile2:2341: recipe for target 'svxlink/trx/CMakeFiles/trx.dir/all ' failed
    make[1]: *** [svxlink/trx/CMakeFiles/trx.dir/all] Error 2
    Makefile:149: recipe for target 'all' failed
    make: *** [all] Error 2
    root@45663:/opt/src/svxlink/src/build#
  • Der Branche ist jetzt im Master Trunk !!!
    bitte vorher folgende Pakete installieren:
    sudo apt-get install libcurl4-openssl-dev
    sudo apt install libjsoncpp-dev
    Ich musste von Jessie auf Strech upgraden,weil man eine höhere Version von libjsoncpp-dev braucht.
    Mit Jessie hatte ich nur die 0.6 zu Verfügung.
    Durch den Versuch das Paket manuell zu installieren gab es Abhängigkeitsfehler.
    Upgrade Jessie to Strech
    https://www.datenreise.de/rasp…uf-stretch-aktualisieren/
    Danach hat man die Versionsnummer libjsoncpp-dev.17...und es funktioniert :)
    Regelmäßig Updates der SvxLink-Sourcen einspielen und installieren
    Möchte man auf die neuste Version updaten so wechseln Sie einfach in das Verzeichnis svxlink
    (also i. A. /home/Rufzeichen/svxlink) und geben den Befehl
    git pull ein.
    Danach führen Sie folgende Befehle aus
    cd src/build
    make clean
    make
    sudo make install
    Weitere Infos https://groups.io/g/svxlink/to…Fsticky,,,20,2,0,40999696
    ich hänge mich mal in dieses Thema mit rein, da ich wohl das gleiche Problem habe.
    1.
    ist ausgeführt.
    2.
    git pull läuft durch
    make produziert folgendes:
    [  9%] Building CXX object async/audio/CMakeFiles/asyncaudio.dir/AsyncAudioDecoderOpus.cpp.o
    [  9%] Building CXX object async/audio/CMakeFiles/asyncaudio.dir/AsyncAudioDeviceAlsa.cpp.o
    [  9%] Building CXX object async/audio/CMakeFiles/asyncaudio.dir/AsyncAudioDeviceOSS.cpp.o
    make[2]: *** Keine Regel vorhanden, um das Ziel „/usr/lib/libopus.so“,
    benötigt von „lib/libasyncaudio.so.1.6.0.99.3“, zu erstellen.  Schluss.
    CMakeFiles/Makefile2:932: die Regel für Ziel „async/audio/CMakeFiles/asyncaudio.dir/all“ scheiterte
    make[1]: *** [async/audio/CMakeFiles/asyncaudio.dir/all] Fehler 2
    Makefile:149: die Regel für Ziel „all“ scheiterte
    make: *** [all] Fehler 2
    sysop@db0per-svx ~/svxlink/src/build $
    Ich vermute, daß irgendwas fehlt. Nur was?
    73 Mario / DJ6WF
  • so, hab mal komplett von vorn angefangen:
    sysop@db0per-svx ~/svxlink/src/build $ sudo cmake -DUSE_QT=OFF -DCMAKE_INSTALL_PREFIX=/usr -DSYSCONF_INSTALL_DIR=/etc -DLOCAL_STATE_DIR=/var -DCMAKE_BUILD_TYPE=Release ..
    gibt folgende Ausgabe:
    Ich kann auch gern noch die Ausgaben von
    CMakeOutput.log
    CMakeError.log
    einstellen.
    Ich bin kein Linux-Experte, aber meine Vermutung ist, daß es mit der "FindRtlSdr.cmake" zusammenhängt.
    73 Mario
  • Ich antworte mal selbst:
    Da ich keinen RTLSDR Stick auf diesem System habe, habe ich die "FindRtlSdr.cmake" umbenannt und das Ganze nochmal von vorne gestartet. make lief durch, make install ebenso, damit ist dieses Update erfolgreich verlaufen.
    73 Mario
  • Hallo Mario
    Habe heute erst im Forum reingeschaut.
    Lese das du es selbst gelöst hast.
    Herzlichen Glückwunsch :)
    Ich wäre aber nicht darauf gekommen das es am RTL FindRtlSdr.cmake liegt.
    73 Jürgen
  • Hallo Jürgen,
    Gedankengang war folgender: Die Installation brach bereits im cmake ab. Hier war die Zeile 11 der Ausgabe interessant:
    [RTLSDR_INCLUDE_DIR (ADVANCED)] ...
    Da ich ja wie gesagt keinen SDR-Stick an diesem System habe, suchte ich mal nach cmake-files welche irgendwas mit rtlsdr zu tun haben und wurde fündig.
    73 Mario / DJ6WF
