Bitte um Hilfe
Hab heute neuer SVXLINK installiert kann aber nicht starten Fehler Meldung:
/usr/share/svxlink/events.tcl in logic NetLogic: missing close-brace: possible unbalanced brace in comment*** ERROR: Could not initialize Logic object "NetLogic". Skipping...Starting logic: MicLogicLoading RX: MicRx1*** ERROR: Open capture audio device failed: No such file or directory*** ERROR: Could not open audio device for receiver "MicRx1"*** ERROR: Could not initialize RX "MicRx1"*** ERROR: Could not initialize Logic object "MicLogic". Skipping...*** ERROR: No logics available. Bailing out...
Und hier mein svxlink.conf:
# Configuration file for the SvxLink server #
[GLOBAL]
MODULE_PATH=/usr/lib/arm-linux-gnueabihf/svxlink
LOGICS=SimplexLogic,NetLogic,MicLogic
CFG_DIR=svxlink.d
TIMESTAMP_FORMAT="%c"
CARD_SAMPLE_RATE=48000
#CARD_CHANNELS=1
LOCATION_INFO=LocationInfo
LINKS=LocalLink,NetLink
[SimplexLogic]
TYPE=Simplex
RX=Rx1
TX=Tx1
MODULES=ModuleHelp,ModuleParrot,ModuleEchoLink,ModuleMetarInfo
CALLSIGN=DH1AA-L
SHORT_IDENT_INTERVAL=60
LONG_IDENT_INTERVAL=60
#IDENT_ONLY_AFTER_TX=4
#EXEC_CMD_ON_SQL_CLOSE=500
EVENT_HANDLER=/usr/share/svxlink/events.tcl
DEFAULT_LANG=de_DE
RGR_SOUND_DELAY=-1
#REPORT_CTCSS=136.5
#TX_CTCSS=ALWAYS
MACROS=Macros
FX_GAIN_NORMAL=0
FX_GAIN_LOW=-12
#ACTIVATE_MODULE_ON_LONG_CMD=4:EchoLink
QSO_RECORDER=8:QsoRecorder
#ONLINE_CMD=998877
#MUTE_RX_ON_TX=1
#MUTE_TX_ON_RX=1
#STATE_PTY=/var/run/svxlink/state
[QsoRecorder]
REC_DIR=/var/spool/svxlink/qso_recorder
#MIN_TIME=1000
MAX_TIME=3600
SOFT_TIME=300
MAX_DIRSIZE=1024
DEFAULT_ACTIVE=0
#TIMEOUT=300
#QSO_TIMEOUT=300
ENCODER_CMD=/usr/bin/oggenc -Q \"%f\" && rm \"%f\"
[LocalLink]
CONNECT_LOGICS=SimplexLogic,MicLogic
DEFAULT_ACTIVE=1
[NetLogic]
TYPE=Repeater
RX=NetRx
TX=NetTx
CALLSIGN=DH1AA
OPEN_ON_SQL=20
IDLE_TIMEOUT=0
OPEN_SQL_FLANK=OPEN
NO_REPEAT=1
[NetLink]
NAME=Net
#CONNECT_LOGICS=SimplexLogic,NetLogic
CONNECT_LOGICS=SimplexLogic:34,NetLogic:35
DEFAULT_ACTIVE=1
[NetRx]
TYPE=Net
HOST=ip richtig
TCP_PORT=5300
AUTH_KEY=pwd
CODEC=OPUS
#OPUS_ENC_FRAME_SIZE=20
#OPUS_ENC_COMPLEXITY=10
#OPUS_ENC_BITRATE=20000
#OPUS_ENC_VBR=1
LOG_DISCONNECTS_ONCE=1
[NetTx]
TYPE=Net
HOST=ip richtig
TCP_PORT=5300
AUTH_KEY=pwd
CODEC=OPUS
#OPUS_ENC_VBR=1
[MicLogic]
TYPE=Simplex
RX=MicRx1
TX=MicTx1
CALLSIGN=DH1AA-E74DD
NOREPEAT=0
IDLE_TIMEOUT=10
OPEN_ON_SQL=20
DEFAULT_LANG=de_DE
OPEN_SQL_FLANK=OPEN
[MicRx1]
TYPE=Local
AUDIO_DEV=alsa:plughw:2
AUDIO_CHANNEL=0
#SQL_DET=VOX
#SQL_START_DELAY=0
#SQL_DELAY=0
#SQL_HANGTIME=500
#SQL_TIMEOUT=600
#VOX_FILTER_DEPTH=20
#VOX_THRESH=1000
SQL_DET=GPIO
GPIO_SQL_PIN=gpio9
#CTCSS_FQ=136.5
#SERIAL_PORT=/dev/ttyS0
#SERIAL_PIN=CTS:SET
#GPIO_SQL_PIN=gpio3
SIGLEV_SLOPE=1
SIGLEV_OFFSET=0
SIGLEV_OPEN_THRESH=30
SIGLEV_CLOSE_THRESH=10
DEEMPHASIS=0
DTMF_DEC_TYPE=INTERNAL
DTMF_MUTING=1
DTMF_HANGTIME=100
#DTMF_SERIAL=/dev/ttyS0
[MicTx1]
TYPE=Local
AUDIO_CHANNEL=0
PTT_TYPE=NONE
PTT_PORT=/dev/ttyUSB1
PTT_PIN=DTRRTS
TIMEOUT=3000
TX_DELAY=0
PREEMPHASIS=0
DTMF_TONE_LENGTH=100
DTMF_TONE_SPACING=50
DTMF_DIGIT_PWR=-15
[Macros]
1=EchoLink:853418#
2=EchoLink:967332#
3=EchoLink:819613#
4=EchoLink:558628#
5=EchoLink:558817#
6=EchoLink:232503#
7=EchoLink:740751#
8=EchoLink:6494#
9=EchoLink:9999#
[Rx1]
TYPE=Local
AUDIO_DEV=alsa:plughw:1
AUDIO_CHANNEL=0
SQL_DET=GPIO
GPIO_SQL_PIN=gpio3
SQL_START_DELAY=100
SQL_DELAY=100
SQL_HANGTIME=500
#SQL_DET=SERIAL
#SQL_START_DELAY=0
#SQL_DELAY=0
#SQL_HANGTIME=0
#SQL_EXTENDED_HANGTIME=1000
#SQL_EXTENDED_HANGTIME_THRESH=15
#SQL_TIMEOUT=600
#VOX_THRESH=1000
#CTCSS_MODE=2
#CTCSS_FQ=136.5
#CTCSS_SNR_OFFSET=0
#CTCSS_OPEN_THRESH=15
#CTCSS_CLOSE_THRESH=9
#CTCSS_BPF_LOW=60
#CTCSS_BPF_HIGH=270
#SERIAL_PORT=/dev/ttyUSB0
#SERIAL_PIN=CTS
#SERIAL_SET_PINS=DTR!RTS
#EVDEV_DEVNAME=/dev/input/by-id/usb-SYNIC_SYNIC_Wireless_Audio-event-if03
#EVDEV_OPEN=1,163,1
#EVDEV_CLOSE=1,163,0
#GPIO_SQL_PIN=gpio3
#PTY_PATH=/tmp/rx1_sql
#HID_DEVICE=/dev/hidraw3
#HID_SQL_PIN=VOL_UP
#SIGLEV_DET=TONE
SIGLEV_SLOPE=1
SIGLEV_OFFSET=0
#SIGLEV_BOGUS_THRESH=120
#TONE_SIGLEV_MAP=100,84,60,50,37,32,28,23,19,8
DEEMPHASIS=0
SQL_TAIL_ELIM=200
PREAMP=15
PEAK_METER=1
AUDIO_FILTER=HpBe1/1000
DTMF_MUTING=1
DTMF_HANGTIME=100
#DTMF_SERIAL=/dev/ttyUSB0
#DTMF_PTY=/tmp/rx1_dtmf
#DTMF_MAX_FWD_TWIST=8
#DTMF_MAX_REV_TWIST=4
1750_MUTING=1
#SEL5_DEC_TYPE=INTERNAL
#SEL5_TYPE=ZVEI1
#FQ=433475000
#WBRX=WbRx1
[Tx1]
TYPE=Local
AUDIO_CHANNEL=0
#PTT_TYPE=SerialPin
#PTT_PORT=/dev/ttyUSB0
#PTT_PIN=RTS
PTT_TYPE=GPIO
PTT_PIN=gpio10
#PTT_HANGTIME=1000
TIMEOUT=300
TX_DELAY=500
AUDIO_FILTER=LpBe1/1000
#CTCSS_FQ=136.5
#CTCSS_LEVEL=9
PREEMPHASIS=0
DTMF_DIGIT_PWR=-15
MASTER_GAIN=2.0
[LocationInfo]
APRS_SERVER_LIST=euro.aprs2.net:14580
STATUS_SERVER_LIST=aprs.echolink.org:5199
LON_POSITION=6.59.44E
LAT_POSITION=50.31.10N
CALLSIGN=EL-DH1AA
FREQUENCY=433.450
TX_POWER=2
ANTENNA_GAIN=6
ANTENNA_HEIGHT=5m
ANTENNA_DIR=-1
PATH=WIDE1-1
BEACON_INTERVAL=10
#TONE=136
COMMENT=SvxLink by SM0SVX (svxlink.sourceforge.net)
Display More
73 de dzevad dh1aa
